標題: [排位] 澳洲二級賽 - 昆士蘭堅尼 鷹園 三歲 1600m
帖子 71146
發表於 28/4/2023 09:12 PM  資料 短消息
Of $350,000.1st $203,000, 2nd $64,750, 3rd $33,250, 4th $17,500, 5th $9,625, 6th $4,375, 7th $4,375, 8th $4,375, 9th $4,375, 10th $4,375
A deduction for Animal Care will be applied to all prizemoney prior to distribution at the rate of 1% for prizemoney pools less than $250,000.00 and 5% for pools $250,000.00 and higher.GROUP 2
Set Weights, Three-Years-Old, Apprentices cannot claim.
Field Limit: 18 + 5 EM    NOMINATIONS EXTENDED TO: 25/04/2023 10:00:00 AM
1        4x81431x0        PERFECT THOUGHT        John Sargent        Tim Clark        14        57kg                        84
2        152732x301        THE FORTUNE TELLER        Ciaron Maher & David Eustace        Ben Melham        3        57kg                        91
3        41111x3        KOVALICA (NZ)        Chris Waller        Nash Rawiller        11        57kg                        81
4        3x607x4637        BROSNAN        Gerald Ryan & Sterling Alexiou        Brenton Avdulla        6        57kg                        80
5        315x511111        THE VOWELSQTISx        Toby & Trent Edmonds        James Orman        16        57kg                        85
6        1544242310        TAPILDOODLEDO (NZ)        Kerry Taplin        Mark Du Plessis        12        57kg                        80
7        32x3124255        WAITAK (NZ)        Lance O'Sullivan & Andrew Scott        Ben Thompson        8        57kg                        88
8        100x1765x7        COCOBREW EXPRESSQTISx        Ryan Tyrell & Tom Button        Ms Angela Jones (a)        1        57kg                        69
9        2x135x2404        BROOKHAVENQTISx        Chris Munce        Justin Huxtable        15        57kg                        64
10        31x552x33        BULIKOV        Robert Heathcote        Ashley Morgan        9        57kg                        66
11        1383        YASUKE        Chris Waller        Damien Thornton        10        57kg                        64
12        24x6123        MAGADAN        Peter & Paul Snowden        Chad Schofield        5        57kg                        64
13        5x8731x271        NIPPA’S NIGHTCAP        Kelly Schweida        Taylor Marshall        4        57kg                        64
14        8x317        RISING PACIFIC (NZ)        Tony Gollan        Ryan Maloney        13        57kg                        62
15        x4613122x0        NOAH ’N’ A DEEL        Les Kelly        Sean Cormack        2        55kg                        69
16        3193x1        LADY LE DAQTISx        Paul Jenkins        Jim Byrne        7        55kg                        64
當前時區 GMT+8, 現在時間是 25/10/2026 10:29 PM
Processed in 0.026697 second(s), 9 queries , Gzip enabled
