標題: 澳洲三級賽 -- Rough Habit Plate 東奔 三歲 2000m
帖子 71146
發表於 12/5/2023 11:14 PM  資料 短消息
Of $250,000.1st $145,000, 2nd $46,250, 3rd $23,750, 4th $12,500, 5th $6,875, 6th $3,125, 7th $3,125, 8th $3,125, 9th $3,125, 10th $3,125
A deduction for Animal Care will be applied to all prizemoney prior to distribution at the rate of 1% for prizemoney pools less than $250,000.00 and 5% for pools $250,000.00 and higher.GROUP 3
Set Weights, Three-Years-Old, Apprentices cannot claim.
Field Limit: 16 + 5 EM    NOMINATIONS EXTENDED TO: 09/05/2023 10:00:00 AM
1        41111x31        KOVALICA (NZ)        Chris Waller        James McDonald        10        57kg                        92
2        15x5111113        THE VOWELSQTISx        Toby & Trent Edmonds        James Orman        7        57kg                        87
3        5442423109        TAPILDOODLEDO (NZ)        Kerry Taplin        Mark Du Plessis        14        57kg                        80
4        2x31242557        WAITAK (NZ)        Lance O'Sullivan & Andrew Scott        Ben Thompson        11        57kg                        87
5        133x92268        STROKE OF LUCK        John O'Shea        Nash Rawiller        3        57kg                        73
6        x135x24045        BROOKHAVENQTISx        Chris Munce        Justin Huxtable        1        57kg                        68
7        31x552x334        BULIKOV        Robert Heathcote        Joshua Parr        13        57kg                        69.5
8        13833        YASUKE        Chris Waller        Tim Clark        9        57kg                        64
9        321x39231        SNIZZI        Paul Messara        Ms Samantha Collett        15        57kg                        64
10        73x17833        CUT ON A DIME        Bryce Heys        Damien Thornton        6        57kg                        64
11        8x24212x71        XTRAREVZ        John Sargent        Kerrin McEvoy        12        57kg                        65
12        4x625117        BURNT BY BERNIE        Annabel Neasham        Ryan Maloney        17        57kg                        64
13        12        HEIKA        Paul Messara        Kyle Wilson-Taylor        4        57kg                        60
14        51        FLASH PRINCEQTISx        Bryan Dais        Taylor Marshall        8        57kg                        60
15        8x9218x36        UNTETHERED (NZ)        Michael Moroney        Jake Bayliss        2        57kg                        63
16        5130x8202        SO DAZZLING (NZ)        John Sargent        Craig Williams        16        55kg                        94
17e        7309421        SPECIAL SWEY (NZ)        Chris Waller        Tyler Schiller (a)        5        57kg                        62
當前時區 GMT+8, 現在時間是 25/10/2026 10:29 PM
Processed in 0.020831 second(s), 9 queries , Gzip enabled
