標題: 澳洲三級賽 -- CHAIRMAN'S HANDICAP 東奔 三歲或以上 2000m
帖子 71146
發表於 12/5/2023 11:15 PM  資料 短消息
Of $200,000.1st $116,000, 2nd $37,000, 3rd $18,000, 4th $9,750, 5th $5,500, 6th $2,750, 7th $2,750, 8th $2,750, 9th $2,750, 10th $2,750
A deduction for Animal Care will be applied to all prizemoney prior to distribution at the rate of 1% for prizemoney pools less than $250,000.00 and 5% for pools $250,000.00 and higher.GROUP 3
Quality, Minimum Weight 54kg, Apprentices cannot claim.
Field Limit: 16 + 5 EM
1        x344505144        PLATINUM INVADOR (NZ)        Lisa Latta        Ryan Maloney        11        58.5kg                        103
2        3x54250x50        YONKERS (USA)        Chris Waller        James McDonald        8        58.5kg                        103
3        0030x23102        CEPHEUS (GB)        Matthew Dunn        Nash Rawiller        6        58kg                        102
4        248x972238        NERVE NOT VERVE (NZ)        Michael Moroney        Joshua Parr        15        56.5kg                        103
5        15x8174x76        LONDON BANKER (NZ)        Kelly Schweida        James Orman        12        56kg                        98
6        8x074506x0        WARNING        Anthony & Sam Freedman        Ben Thompson        10        54.5kg                        95
7        14210x6586        WILD CHAP        Brett Lazzarini        Taylor Marshall        5        54kg                        91
8        x18x0x9212        KALAPOUR (IRE)        Kris Lees        Tim Clark        13        54kg                        89
9        311211x086        OTYRAR (GB)        Chris Waller        Damien Thornton        9        54kg                        86
10        72488x1174        DUNE FORTY FIVEQTISx        Robert Heathcote        Kyle Wilson-Taylor        2        54kg                        85
11        42311x6173        RED WAVEQTISx        Tony & Maddysen Sears        Ms Angela Jones (a)        3        54kg                        84
12        4142x56507        YAPHET        Cliff Brown        Tyler Schiller (a)        1        54kg                        84
13        x211030741        SECRET GLAMOUR        Ciaron Maher & David Eustace        Craig Williams        7        54kg                        82
14        1257x64615        STUCK WITH YOU (NZ)        Matthew Dunn        Kerrin McEvoy        4        54kg                        82
15        5549x76122        SOUTHERN STOCK (NZ)        Chris Munce        Mark Du Plessis        14        54kg                        78
當前時區 GMT+8, 現在時間是 25/10/2026 10:29 PM
Processed in 0.012991 second(s), 7 queries , Gzip enabled
