標題: [排位] 澳洲三級賽 -- PREMIER'S CUP 東奔 三歲或以上 2200m
帖子 71146
發表於 27/5/2023 10:28 PM  資料 短消息
Of $200,000.1st $116,000, 2nd $37,000, 3rd $18,000, 4th $9,750, 5th $5,500, 6th $2,750, 7th $2,750, 8th $2,750, 9th $2,750, 10th $2,750
A deduction for Animal Care will be applied to all prizemoney prior to distribution at the rate of 1% for prizemoney pools less than $250,000.00 and 5% for pools $250,000.00 and higher.GROUP 3
Quality, Minimum Weight 54kg, Apprentices cannot claim.
Field Limit: 18 + 5 EM    NOMINATIONS EXTENDED TO: 23/05/2023 10:00:00 AM
1        35x5302x85        FANCY MAN (IRE)        Annabel Neasham        Chad Schofield        11        59kg                        103
2        x344505144        PLATINUM INVADOR (NZ)        Lisa Latta        Ryan Maloney        5        59kg                        103
3        x0x09020x1        SERPENTINE (IRE)        Gai Waterhouse & Adrian Bott        Tim Clark        9        58.5kg                        102
4        18x0x92121        KALAPOUR (IRE)        Kris Lees        Blake Shinn        13        56.5kg                        98
5        890627x053        KUKERACHA (NZ)        Chris Waller        James McDonald        7        56.5kg                        98
6        5x8174x760        LONDON BANKER (NZ)        Kelly Schweida        James Orman        10        56kg                        97
7        7885x78x00        SOUTHERN FRANCE (IRE)        Matthew Smith        Larry Cassidy (late alt)        3        56kg        56.5kg                97
8        x074506x00        WARNING        Anthony & Sam Freedman        Jason Collett        2        54kg                        93
9        2488x11742        DUNE FORTY FIVEQTISx        Robert Heathcote        Craig Williams        1        54kg                        88
10        11211x0864        OTYRAR (GB)        Chris Waller        Damien Thornton        4        54kg                        86
11        3045110001        TAPPY’S LAD (NZ)        Kerry Taplin        Mark Du Plessis        6        54kg                        84
12        142x565070        YAPHET        Cliff Brown        Tyler Schiller (a)        12        54kg                        84
13        549x761220        SOUTHERN STOCK (NZ)        Chris Munce        Ben Thompson        8        54kg                        78
當前時區 GMT+8, 現在時間是 25/10/2026 10:30 PM
Processed in 0.027875 second(s), 12 queries , Gzip enabled
