標題: [排位] 澳洲一級賽 - 昆士蘭打比 東奔 三歲 2400m
帖子 71050
港元 10325 萬
發表於 27/5/2023 10:29 PM  資料 短消息
Of $1,000,000.1st $600,000, 2nd $180,000, 3rd $90,000, 4th $45,000, 5th $25,000, 6th $12,000, 7th $12,000, 8th $12,000, 9th $12,000, 10th $12,000
A deduction for Animal Care will be applied to all prizemoney prior to distribution at the rate of 1% for prizemoney pools less than $250,000.00 and 5% for pools $250,000.00 and higher.GROUP 1
Set Weights, Three-Years-Old, Apprentices cannot claim.
QTISx Group 1
Field Limit: 18 + 5 EM
1        41111x313        KOVALICA (NZ)        Chris Waller        James McDonald        5        57kg                        102
2        5x51111132        THE VOWELSQTISx        Toby & Trent Edmonds        James Orman        14        57kg                        87
3        3243x133        ABERFELDIE BOY        Robbie Griffiths & Mathew de Kock        Craig Newitt        8        57kg                        88
4        80x9229112        PROMISES KEPT        Ciaron Maher & David Eustace        Mark Zahra        1        57kg                        89
5        x549x41727        ANDALUS (NZ)        John O'Shea        Blake Shinn        19        57kg                        89
6        4424231095        TAPILDOODLEDO (NZ)        Kerry Taplin        Ben Thompson        7        57kg                        80
7        x312425570        WAITAK (NZ)        Lance O'Sullivan & Andrew Scott        Jake Bayliss        15        57kg                        86
8        73094211        SPECIAL SWEY (NZ)        Chris Waller        Nash Rawiller        17        57kg                        81
9        133x922683        STROKE OF LUCK        John O'Shea        Ben Melham        4        57kg                        76
10        4201120114        SMARTAWI        Gregory Hickman        Tyler Schiller (a)        18        57kg                        69
11        4x2521615        ARBY (NZ)        Darryn & Briar Weatherley        Sam Weatherley        16        57kg                        84
12        73x178334        CUT ON A DIME        Bryce Heys        Damien Thornton        2        57kg                        68
13        2x442x312        THE ENGLISHMAN (NZ)        Peter & Paul Snowden        Chad Schofield        13        57kg                        64
14        3x322x6411        FAME        Peter G Moody        Jason Collett        12        57kg                        67
15        x24212x716        XTRAREVZ        John Sargent        Joshua Parr        6        57kg                        65
16        1321        SACRED MISSION (NZ)        David Vandyke        Craig Williams        10        57kg                        66
17        98x4x52614        AMALGAMATION        Marcus Wilson        Ms Samantha Collett        20        57kg                        61
18        786166        TRUE BLUE        Matthew Smith        Opie Bosson        11        57kg                        58
19e        98352742        SUBARCTIC        Matthew Smith        Larry Cassidy (late alt)        9        57kg
20e        765551        ARTFUL GIRLQTISx        Kevin Kemp        Marnu Potgieter (a)        3        55kg                        57
UID 2384
帖子 809
港元 555 萬
註冊 24/1/2006
發表於 28/5/2023 01:40 AM  資料 主頁 短消息
頭馬上下線都是紐西蘭馬
當前時區 GMT+8, 現在時間是 9/10/2026 05:10 AM
Processed in 0.010480 second(s), 9 queries , Gzip enabled
