標題: [排位] 澳洲三級賽 -- 短途錦標 東奔 三歲或以上 1350m
帖子 70976
港元 10306 萬
發表於 23/5/2025 11:59 PM  資料 短消息
Of $300,000.1st $174,000, 2nd $55,500, 3rd $28,500, 4th $15,000, 5th $8,250, 6th $3,750, 7th $3,750, 8th $3,750, 9th $3,750, 10th $3,750
A deduction for Animal Care will be applied to all prizemoney prior to distribution at the rate of 1% for prizemoney pools less than $250,000.00 and 5% for pools $250,000.00 and higher.
A deduction for Insurance will be applied to all prizemoney prior to distribution at the rate of 1% on prizemoney pools for TAB races.GROUP 3
Quality, Minimum Weight 54kg, Apprentices cannot claim.
Field Limit: 16 + 5 EM
1        51x2143x5x        YELLOW BRICKQTISx        Tony & Maddysen Sears        Andrew Mallyon        7        60kg                        107
2        3x14x410x0        FAR TOO EASY        David McColm        Craig Williams        12        59kg                        105
3        49832x8587        FREEDOM RALLY        Tony Gollan        Ryan Maloney        3        59kg                        105
4        231322x51x        IKNOWASTAR        Bjorn Baker        Ms Rachel King        1        59kg                        105
5        122111x164        RISE AT DAWN (NZ)        Ben, Will & JD Hayes        Mark Zahra        13        59kg                        105
6        x412x8050x        ATTRACTABLE        Sara Ryan        Nash Rawiller        11        58kg                        103
7        21811x1520        WILLAIDOW        Marc Conners        Jason Collett        14        58kg                        103
8        x22132x020        CIFRADOQTISx        Rex Lipp        Ms Cejay Graham        2        57.5kg                        102
9        38x876x1x2        PIER (NZ)        Darryn & Briar Weatherley        Ethan Brown        21        57kg                        101
10        91123x3611        ROCKRIBBED        Tony Gollan        Ms Emily Lang (a)        19        56.5kg                        100
11        11x2380x21        WAR MACHINE (NZ)        Ben, Will & JD Hayes        Blake Shinn        6        56.5kg                        100
12        23x66276x0        COLEMAN        Chris Waller        James McDonald        4        56kg                        100
13        20x31611x3        TRANSATLANTIC        Tony Gollan        Regan Bayliss        15        56kg                        99
14        3734x167x0        ABOUNDINGQTISx        Robert Heathcote        Tommy Berry        16        55.5kg                        102
15        21x2030x79        XIDAKI        Peter Snowden        Kerrin McEvoy        5        55.5kg                        98
16        652x2x3114        MATCHA LATTE        Sara Ryan        Kyle Wilson-Taylor        18        55kg                        97
17e        x3134x43x4        BOOM TORQUEQTISx        Matthew Dunn        Damien Thornton        10        55kg                        97
18e        222x94210x        ESTADIO MESTALLA (IRE)        Joseph Pride        Tim Clark        8        55kg                        97
19e        1x6310588x        RED WAVEQTISx        Tony & Maddysen Sears        Jag Guthmann-Chester        9        54.5kg                        96
20e        x5831200x7        OUGHTON        Melissa Kelly        Robbie Dolan        17        54kg                        93
21e        115x1332x4        WARNIE (IRE)        Ciaron Maher                20        54kg                        92
當前時區 GMT+8, 現在時間是 27/9/2026 02:05 PM
Processed in 0.010971 second(s), 9 queries , Gzip enabled
