標題: 澳洲三級賽 -- CHAIRMAN'S HANDICAP 東奔 三歲或以上 2000m
帖子 71187
發表於 15/5/2026 11:50 PM  資料 短消息
Of $200,000.1st $116,000, 2nd $37,000, 3rd $18,000, 4th $9,750, 5th $5,500, 6th $2,750, 7th $2,750, 8th $2,750, 9th $2,750, 10th $2,750
A deduction for Animal Care will be applied to all prizemoney prior to distribution at the rate of 1% for prizemoney pools less than $250,000.00 and 5% for pools $250,000.00 and higher.
A deduction for Insurance will be applied to all prizemoney prior to distribution at the rate of 1% on prizemoney pools for TAB races.GROUP 3
Quality, Minimum Weight 54kg, Apprentices cannot claim.
Field Limit: 16 + 5 EM
1        034361114x        FUTURE HISTORY (GB)        Gregory Hickman        Nash Rawiller        12        60.5kg                        108
2        x509033x89        MIDDLE EARTH (GB)        Ciaron Maher        Ethan Brown        5        60.5kg                        108
3        10x6x36x65        ALALCANCE (GB)        Gai Waterhouse & Adrian Bott        Martin Harley        11        58.5kg                        108
4        00112150x0        ROYAL SUPREMACY (IRE)        Ciaron Maher        Mark Zahra        4        58.5kg                        104
5        0x929x9300        JUST FINE (IRE)        Gai Waterhouse & Adrian Bott        Tim Clark        8        58kg                        103
6        136x107x07        SEA KING (GB)        Matthew Dunn        Zac Purton        13        57kg                        101
7        1585x72016        ENCODERQTISx        Michael Freedman        Tommy Berry        3        56kg                        99
8        4215x70492        NELLIE LEYLAX (IRE)        Annabel & Rob Archibald        Ben Thompson        1        54.5kg                        96
9        1111143x06        WALSH BAY        Chris & Corey Munce        Ms Tahlia Fenlon (a)        7        54kg                        99
10        x9712043x6        IMPERIALIST (NZ)        Chris Waller                16        54kg                        95
11        9202829x55        BELVEDERE BOYS        Matthew Dunn        Jake Bayliss        9        54kg                        94
12        x324118966        KIND WORDS        Kris Lees        Daniel Moor        2        54kg                        92
13        52215917x6        SUN WORSHIPPERQTISx        Matt Kropp        Mark Du Plessis        10        54kg                        92
14        x968846140        ZOOLOGY (GB)        Peter & Will Hulbert        Jace McMurray (a)        15        54kg                        91
15        351200x731        SO YOU ARE        Stirling Osland        Ms Cejay Graham        14        54kg                        88
16        528527x870        LA COMETA (NZ)        Shaun Dwyer        Taylor Marshall        6        54kg                        73
當前時區 GMT+8, 現在時間是 1/11/2026 02:08 AM
Processed in 0.015224 second(s), 7 queries , Gzip enabled
